branchbiker
Feb 16, 2020Apprentice
How to access CM1200 Hidden Debug Logs?
Some Netgear cable modems have more detailed debug logs that are accessible via some hidden web pages. I can't find those for the CM1200. I'm dealing with a WAN Aggreggation issue that slows my spe...
Feb 17, 2020Guru - Experienced User
This is already a known issue:
If you have the 1200, you'll need to keep LAG disabled until this issue is solved.
CM modems do not have any hidden logs. All logs are posted to the main log UI under 192.168.100.1.
- branchbikerFeb 17, 2020Apprentice
According to Netgear the issue is not officially in the "known issues" list. Which is why I have a case open escallated to Engineering.
- FURRYe38Feb 17, 2020Guru - Experienced User
You and everyone else in that forum post. Again it's known.
Maybe not known to some phone support personnel.
For now, you'll have to wait for NG and ISPs to solve this. Once is solved and NG/ISP deem it fixed and the new FW works with out issues during there testing, then ISPs will push it to the users modem and not before.
So for now, leave LAG disabled.
Good Luck.
FURRYe38 Does the CM1100 have the same issue? I can easily return the 1200 and just get the 1100. I don't need 4 ports (just 2).
