kdawg67
Apr 13, 2022Aspirant
How to allow a Nest Protect to connect to the 2.4ghz network on a dual band Router
I'm trying to set up a new Nest Protect and it requires a 2.4ghz network. What do I need to do to my router to allow it to connect? Is there a way to turn off or deprioritize the 5G network to comple...
kdawg67
Apr 14, 2022Aspirant
Thanks,@michaelkenward,
To answer your question, 'it' refers to the Nest Protect device.
I will follow your instructions and see how it goes. I did try this already, but with slightly different steps and wasn't successful. User error most likely. When you say 'go into the router's wifi settings', you mean through it's IP address, correct? Which is what I did previously, but want to clarify before proceeding.
michaelkenward
Apr 15, 2022Guru - Experienced User
The Nest device will connect to the router's wifi.
The challenge is to set it up with whatever mobile device you are using.
The issue has come up here several times over the years:
Search - NETGEAR Communities – Nest Protect
