WayneStation
Aug 12, 2020Aspirant
How to analyze the cable signal over long term?
I have Cox cable and a C6300BD Cable Modem/Router and everything was great for many years. I use a VPN connection for work from home. Then Cox had a major outage for a couple of days. They said it wa...
- Aug 13, 2020
Not with this modem. Only think you can try to use is pingplotter.com and see if that helps any.
There were some broadcom based modems that had built in analyzers, those were mostly seen on stand alone modems.
Aug 12, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
Has a factory reset and setup from scratch been performed?
- WayneStationAug 12, 2020Aspirant
ISP is practically useless; it took almost a week to get them out with a complete outage. It takes hours on the phone going through useless scripts to get the tech out. That's why I want to prove it myself; hence my question.
There's no splitters, the cable is good, modem has been rebooted and powered off/on. No wifi neighbors nearby and besides - it happens on both ethernet and wi-fi.
Have not factory reset and set up the modem but what I really want to do is analyze the cable signal over a long period of time and get a graph. You are saying that can't be done?
- FURRYe38Aug 13, 2020Guru - Experienced User
- WayneStationAug 20, 2020Aspirant
Thanks, I'll try that ping plotter site and keep monitoring. If Netgear sold a long term pass through analyzer for home use price I bet they'd sell some! I see a good one from Bird RF for $ 4,000 but that's not going to happen!
