guanyu5710's avatar
guanyu5710
Follower
Jul 03, 2017
How to bridge C6300?
I didn't find bridging/repeater settings. Firmware 2.01.18.
  • "Bridging" has many meanings, so please clarify your question.  Are you trying to disable the router functions or are you trying to set it up as a wireless repeater (aka range extender)?  You can disable the router by going to ADVANCED > Administration > Router Mode.  The C6300 cannot function as a repeater.
1 Reply
