anonymous856
Mar 24, 2024Follower
How to connect orbi CBR750 with other Xfinity xfi router
Hi, I want to use my Xfinity xfi cable/modem/router and CBR750 cable router together. My use-case is to connect either xfinity modem or CBR750 to ISP (coaxial cable) and other one via ethernet c...
CrimpOn
Mar 24, 2024Guru - Experienced User
As you have already discovered, the RBR750 is intended to be connected to a coax cable (and is compatible with Xfinity). There is no option to connect it to the Xfinity I do not understand why use of the Xfinity modem is a requirement.
Just to double check, navigate to the Orbi Advanced Tab, Advanced Settings, and see if there is an option to place the RBR750 in Access Point (AP) mode.
