anonymous856
Mar 24, 2024Follower
How to connect orbi CBR750 with other Xfinity xfi router
Hi, I want to use my Xfinity xfi cable/modem/router and CBR750 cable router together. My use-case is to connect either xfinity modem or CBR750 to ISP (coaxial cable) and other one via ethernet c...
Mar 25, 2024Guru - Experienced User
The CBR750 can be a direct replacement to the ISPs supplied cable modem. The CBR series is a gateway modem, thus having a modem and built in router, thus no WAN port will be seen on the CBR series. You'll need to contact the ISP and have them help you get the CBR750 connected to there services.
anonymous856 wrote:
Hi,
I want to use my Xfinity xfi cable/modem/router and CBR750 cable router together. My use-case is to connect either xfinity modem or CBR750 to ISP (coaxial cable) and other one via ethernet cable. And then use the CBR750 satellite connected over wifi in the other rooms. This help me to extend the network without using the ethernet cable across rooms. I do want to use xfi modem as router or bridge because they this gives me infinity data plans.
Please suggest the solution which works for CBR750, because i don't see the WAN port in the back.
