goitmc
May 28, 2017Aspirant
How to connect to DNS server with N450
I have a N450 CG3000Dv2 cable modem/wifi router. It has properly connected to the cable service and all devices on the network have access to the internet. I am trying to connect it to OpenDNS to a...
goitmc
That might be true for the computer but the android devices have the same issue. The properties of the network adapter show DNS server for IPv4 DNS Servers is 192.168.0.1 which is the router. For IPv6 it shows the ISP. Also the adapter shows Obtain DNS server address automatically for both the IP4 and IP6 protocols.
TheEther
May 28, 2017Guru
It's normal for devices to show 192.168.0.1 as the DNS server. The router will forward all DNS queries to the correct DNS servers. I'm not sure if the CG3000DV2 has any settings for IPv6.
- goitmcMay 29, 2017Aspirant
"The router will forward all DNS queries to the correct DNS servers." But its not...that's the problem. The DNS servers I want are listed as described above but nothing is being sent through them. At least the connection is acting as if the ISP servers are being used.
- TheEtherMay 29, 2017Guru
In your original post, you said that you see the OpenDNS and ISP DNS servers listed together. Is that correct? Which ones are listed first?
Was this modem/router provided by the ISP or did you buy it?
The OpenDNS ones are listed first, in IP4 format followed by the ones it's actually using listed in IP6 format. It is a router I purchased. And after years of faithful service using a Linksys router I think I made a mistake switching brands.
