nkoss
Mar 24, 2019Aspirant
how to connect to my modem through browser
--AC3200 WiFi Cable Modem Router, model C7800
above taken directly from the manual title
It is ethernet wired to my computer. In a browser, I enter the URL, 192.168.0.1 (as per the manual) ...
antinode
Mar 24, 2019Guru
> [...] and I get an error message, [...]
Were you not even _slightly_ tempted to reveal what this "an error
message" actually said?
> [...] Why is this happening?
It might be easier for the non-psychics in your audience to determine
that, if the text of that "an error message" were accessible to them.
> [...] as per the manual [...]
Look for "Factory Settings" (or "reset") in that "the manual"?
- nkossMar 24, 2019Aspirant
I'm sorry. I really didn't mean to be cryptic. There really was no message. The signin just kept repeating and I know it was connecting since it said "NETGEAR C7800". I did check the section of factory settings and it suggested using the paper clip in the reset hole. I did that and it did seem to reset and after the bootup, I tried the signin and got the same result. So I am stumped.
OK, this time after several attempts, I got a screen asking for the modem serial number. I entered it and then it asks me 2 security questions.....my first school and best friend's name. Where did it get these questions and how would a brand new machine know the answers? I answered as best I could (not having previously saved this information) and then got a message, "The information you entered does not match what is saved on the router. Please enter it again."
How could the router have any information saved about me? I just bought and installed the thing!!
- nkossMar 25, 2019Aspirant
OK, here is another bit of information I found. The MAC address shown on the bottom of the modem ends in 'C8'. When I notified my provider that I had a new modem/router, that was the MAC address I gave them. I've been doing a little searching and found the command 'arp -a' which yields all the items on my network and their IP and MAC addresses. The modem (at 192.168.0.1) shows the same MAC except for the last 2 digits are 'CA'. Could this be the problem? I will call Cox and see what they have in their system
