dshiznit's avatar
dshiznit
Follower
Jul 06, 2020
How to disable IPv6 on C3700
Hello,
I need to disable IPv6 in order to use VPN over ethernet but am not finding anyway to disable it in the Netgear Genie.  ISP is Xfinity Comcast and comcast said it needs to be configured on Netgear's end to disable IPv6.  I tried running the hotfix exe but get ret=11 (when it needs to be zero).  Any help is greatly appreciated.
Thanks!
1 Reply
  • FURRYe38's avatar
    Log into the modems web page and look under Adavanced Tab/Advanced Settings and see if there is a IPv6 setting there. Review the user manual as well.
