jacobgonzales
Sep 08, 2019Tutor
How to disable ipv6 on nighthawk c7000 modem router
Does anyone know how to disable ipv6 on the nighthawk c7000 I’m trying to remove these 2 dns servers from my router 2607:f428:ffff:ffff::1 2607:f428:ffff:ffff::2
jacobgonzales
Sep 10, 2019Tutor
I do not have paper user Manuel is there a digital version
Sep 10, 2019Guru - Experienced User
Anything in the digital version?
- jacobgonzalesSep 10, 2019TutorNo I could not find any documentation
- FURRYe38Sep 10, 2019Guru - Experienced User
There a reason why your wanting to disable IPv6?
I only see that you can configure IPv6. Auto or Manual. There is no disabling for it. You can disable the Firewall for it. Not sure why one would do this.
- jacobgonzalesSep 10, 2019TutorI’m trying to set up pi hole so all dns traffic goes to one dns but the 2 ipv6 addresses are distributing the traffic into the 3 addresses
