jacobgonzales
Sep 09, 2019Tutor
How to disable ipv6 on nighthawk c7000 modem router
Does anyone know how to disable ipv6 on the nighthawk c7000 I’m trying to remove these 2 dns servers from my router 2607:f428:ffff:ffff::1 2607:f428:ffff:ffff::2
Sep 10, 2019Guru - Experienced User
There a reason why your wanting to disable IPv6?
I only see that you can configure IPv6. Auto or Manual. There is no disabling for it. You can disable the Firewall for it. Not sure why one would do this.
jacobgonzales
Sep 10, 2019Tutor
I’m trying to set up pi hole so all dns traffic goes to one dns but the 2 ipv6 addresses are distributing the traffic into the 3 addresses
- jacobgonzalesSep 10, 2019TutorI just need them disabled cause they are causing conflict
- FURRYe38Sep 10, 2019Guru - Experienced User
I would make contact with NG support and ask about this. File a support ticket:
- jacobgonzalesSep 10, 2019TutorI have filed a support ticket they were not helpful at all
