jacobgonzales
Sep 08, 2019Tutor
How to disable ipv6 on nighthawk c7000 modem router
Does anyone know how to disable ipv6 on the nighthawk c7000 I’m trying to remove these 2 dns servers from my router 2607:f428:ffff:ffff::1 2607:f428:ffff:ffff::2
Sep 10, 2019Guru - Experienced User
Possible that you might need to bridge the modem and install a external router, where you have more IPv6 options. I know the R7800, XR series and Orbi systems have the option to disable IPv6 in there web pages.
jacobgonzales
Sep 10, 2019Tutor
Ya I was hoping I wouldn’t have to do that but how would you go about that solution
- FURRYe38Sep 10, 2019Guru - Experienced User
There is a NAT mode or should be a Bridge mode setting on the C7000. Need to Disable the NAT mode or enable the bridge mode feature on the modem. This will disable all wifi and router functions on the C7000. Thus becomes a modem only. Then connect a external router to the back of the modem and all your devices to the external router.
- jacobgonzalesSep 10, 2019TutorAlright thanks hopefully I won’t have to go down this route but if I do what routers do you recommend I don’t mind spending at etc price point I just want speed and advanced settings
I would review the R7800 first off. Good router. Voxel is working to continuing better FW updates from stock FW.
If you need more wifi to cover more range, you could and EX7700s to the R7800 or go with a Orbi RBK50 series WIFI MESH system.
- jacobgonzalesSep 10, 2019TutorYea I will definitely look into I’ve been looking at ASUS for awhile since they have many (Advanced) options to accommodate gamers
- FURRYe38Sep 11, 2019Guru - Experienced User
Ya heard there good routers for gaming. I do like my XR450. Works well. I wish could recommend the XR700. Can't right now. Theres growth problems with it. :smileyfrustrated:
