jacobgonzales
Sep 09, 2019Tutor
How to disable ipv6 on nighthawk c7000 modem router
Does anyone know how to disable ipv6 on the nighthawk c7000 I’m trying to remove these 2 dns servers from my router 2607:f428:ffff:ffff::1 2607:f428:ffff:ffff::2
jacobgonzales
Sep 11, 2019Tutor
Alright thanks hopefully I won’t have to go down this route but if I do what routers do you recommend I don’t mind spending at etc price point I just want speed and advanced settings
Sep 11, 2019Guru - Experienced User
I would review the R7800 first off. Good router. Voxel is working to continuing better FW updates from stock FW.
If you need more wifi to cover more range, you could and EX7700s to the R7800 or go with a Orbi RBK50 series WIFI MESH system.
- jacobgonzalesSep 11, 2019TutorYea I will definitely look into I’ve been looking at ASUS for awhile since they have many (Advanced) options to accommodate gamers
- FURRYe38Sep 11, 2019Guru - Experienced User
Ya heard there good routers for gaming. I do like my XR450. Works well. I wish could recommend the XR700. Can't right now. Theres growth problems with it. :smileyfrustrated:
