AVinNC's avatar
AVinNC
How to disable remote management when IP address is told 'invalid'
Traffic slowed - checked logs - DOS attacks, Ping of Death, etc.  Remote user login.  Changed router password, changed Wifi passwords (WPA2-PSK).  Checked devices, which from time to time iphones show different IP.
When I try to change remote management to only this computer, by giving it the ipv4 address, it tells me invalid IP.
Thanks
  • > When I try to change remote management to only this computer, by
       What/where is your "this computer"?  _Which_ "the ipv4 address"?  As
    usual, showing actual actions (commands) with their actual results
    (error messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       "Remote Management" refers to access from the outside world, not from
    your own LAN.  If you're trying to limit access from devices on your own
    LAN, then the "admin" password is the only obvious mechanism.
    > [...] Remote user login. [...]
       Again, showing the actual message might be more helpful.  Copy+paste
    is your friend.
    • AVinNC's avatar
      AVinNC
      HI and thanks for you quick reply.  Desktop computer connected to Spectrum cable through ethernet using C3700.  I am trying to block external computers outside my immediate home from connecting, as the router log indicates they are doing.  It seems I can only attach 1 image at time so here is some visual.  Any help appreciated.
      • antinode's avatar
        antinode
        Guru
        > [...] C3700 [...]
           So, not this?:
        > Model: CG3700EMR-1TDNDS|Cable Gateway Docsis 3.0
           "0.0.0.0" is not a real IP address, let alone an outside-world
        address.  I don't know what it means in this context, but I doubt that
        it indicates anything external, friend or foe.  You may be attributing
        more significance to these log entries than they deserve.
           And, as suspected, you're trying to specify a LAN IP address for
        Remote Management, which is not allowed (because it's a nonsense).
