amesjay's avatar
amesjay
How to open all 7 udp ports for amazon echo using the c6300
I have added Amazon Echo ports 123, 443, 4070, 5353, 40317, 49317 and 33434. Only 4070 is open. Is this correct or do I need to do something different to complete setup?
thanks
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    Echo should not need any port forwarding. why are you doing it?
    • amesjay's avatar
      amesjay
      Amazon said UDP ports 123, 443, 4070, 5353, 40317, 49317, and 33434 need to be open to traffic. Echo Alexa needs these ports open to work correctly.
      • vkdelta's avatar
        vkdelta
        It should automatically work as ECHO should support UPnP.
        is it not working?
  • Make sure you know which direction you need to open ports (inbound vs outbound).  That said, I would be surprised if you have to open any ports in the inbound direction for general usage.
