Retired_Member
Dec 01, 2016How to open ports
So I recently got Arlo and realized that the internet light is amber, which mean that there is no internet connection. I contacted support and they told me that I needed to open up ports 80, 123, and...
- Dec 07, 2016
Yes you put the same number in both ports not sure what you mean with opening a port to Netgear.com and yes you put the Ip of the basestation.
DarrenM
DarrenM
Dec 05, 2016Sr. NETGEAR Moderator
Hello Duufhfj
Here is a article on how to port forward on Netgear routers.
DarrenM
- Retired_MemberDec 05, 2016
Thanks for the answer, but I am still confused
If I am only opening one port, I just put the same number for both ports right?
Also, If I am trying to open the port to Netgear.com, where do I put that in?
And for Internal IP, what do I put? IP for the arlo basestation?
- DarrenMDec 07, 2016Sr. NETGEAR Moderator
DarrenM
