TonyMaatouk
Jan 22, 2016Follower
how to pair wifi with 2 Netgear CG300-2stAUS
I have 2 optus netgear CG3000v2 and cant seem to pair the modems up over wifi Router 1 is connected to the internet cable and router 2 is in another room can someone help with the connection not sure if optus has locked the modem down. if I set the router 2 to bridge mode only lan 1 works Wifi is disabled and lan ports 2 -3 are disable
1 Reply
- DarrenMSr. NETGEAR Moderator
Hello TonyMaatouk
Have you tried to just disable the DHCP server on router 2 this is located in the LAN IP setting.
DarrenM
