Mcggen's avatar
Mcggen
How to reset password
I haven't used this router in the last year or so and can't remember my password. Any tell me how to solve this problem please?
    • awood522's avatar
      awood522
      My modem was hacked I need to know how to reset the password
      Its a AC1750 Cable Modem Router Model C6300
      • michaelkenward's avatar
        michaelkenward
        Which password? Wifi? Router?
        You can get both back to the factory settings by pressing the RESET "button" on the back.
        Look at page 101 of the manual:
        C6300 | Product | Support | NETGEAR
    michaelkenward
    You don't say which model you mean, but if you reset to the factory defaults then it will get back to the original settings.
    See the manual. You can find that here somewhere.
  • Anonymous's avatar
    Anonymous
    locate reset button ...push it until power led flashes....after it restarts use default settings on router label
    • kareh's avatar
      kareh
      need to put in a new password after pushing the reset button
        michaelkenward
        Not sure what this refers to, but after the reset, it will flip back to the default password.
        After that you can set a new password.
