polo3's avatar
polo3
How to return to modem+router mode from only modem mode in a C6300?
I have a c6300 and while connecting a TP-Link Deco m5, I decided to set the C6300 to modem only mode.  I use Comcast as ISP. I regret moving my modem to modem only mode, since now I cannot use most of the Ethernet ports (only one physical address at a time) and I guess I could just have switched the wifi radio off with the button in front of the mode.  Anyway, I have tried to access my modem to restablish the mode, but 192.168.0.1 nor 192.168.100.1 give me access to the modem.  How can I go back to modem/Router mode without a factory reset? Thanks!
  • If you can't get in via the 192.168.100.1, try simply factory resetting it.
    push and hold reset for 7-15 seconds while its powered on.
  • plemans's avatar
    • polo3's avatar
      polo3
      This will work, I'm sure, isssue as I was trying to avoid the hard reset... thanjs anyway
  • FURRYe38's avatar
    Log into the modems web page and look under Advanced settings for Mode or Router mode or NAT node. There should be YES or NO. YES means router mode.
