Stangman48
Feb 26, 2022Follower
how to set up network name on a cm1150v cable modem
Hi, i had to pull an old modem off my shelf and it is working with xfinity but i don't see where/how to name my network. any help would be much appreciated - wouldn't think it's this tough but the m...
Feb 27, 2022Guru - Experienced User
The CM1150V isn't a router. Its a modem only device.
It doesn't have a network name or anything like that.
If you're computer is naming it something, that's coming from windows active network profile. You'd have to change that in windows. If that's what you're refering to.
