Dinamo
Jul 25, 2018Aspirant
How to test Netgear C3700 modem/router when loosing connection frequently?
Hi. We lose internet connection at our new address several times a day. It got worse lately. We used the same internet service and the same modem/router at the previous address with a lot less interr...
- Jul 27, 2018
you got major problems in your downstream power levels.
It needs to be around 0 dBmV but you are -15 which is at the edge of the spec.
Dinamo
Jul 26, 2018Aspirant
Additional info:
Signal strength data per Netgear Genie / Wifi Analytics:
between “-17" and “-33" dBm, 66-75%, “good” - right next to the modem/router
between “-44" and “-59" dBm, 40-45%, “poor” - in the same room, but farther from the modem/router; this is the place where we use our laptops
