Dinamo's avatar
Dinamo
How to test Netgear C3700 modem/router when loosing connection frequently?
Hi. We lose internet connection at our new address several times a day. It got worse lately. We used the same internet service and the same modem/router at the previous address with a lot less interr...
  • vkdelta's avatar
    vkdelta
    Jul 27, 2018
    you got major problems in your downstream power levels.
    It needs to be around 0 dBmV but you are -15 which is at the edge of the spec.
