Dinamo
Jul 25, 2018Aspirant
How to test Netgear C3700 modem/router when loosing connection frequently?
Hi. We lose internet connection at our new address several times a day. It got worse lately. We used the same internet service and the same modem/router at the previous address with a lot less interr...
- Jul 27, 2018
you got major problems in your downstream power levels.
It needs to be around 0 dBmV but you are -15 which is at the edge of the spec.
Dinamo
Jul 27, 2018Aspirant
Additional info:
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- vkdeltaJul 27, 2018NETGEAR Employee Retired
- DinamoJul 27, 2018Aspirant
Current data similar to the previous:
Downstream Bonded Channels Chl Status Mod. Ch ID Freq. Hz Power SNR Corr Uncorr 1 Locked QAM256 29 639000000 -11.2dBmV 38.2dB 68 350 2 Locked QAM256 25 609000000 -10.9dBmV 38.9dB 51 182 3 Locked QAM256 26 615000000 -11dBmV 38.6dB 33 204 4 Locked QAM256 27 621000000 -10.9dBmV 38.7dB 40 200 5 Locked QAM256 28 627000000 -10.9dBmV 38.3dB 42 198 6 Locked QAM256 30 645000000 -11.5dBmV 38.2dB 50 200 7 Locked QAM256 31 651000000 -12dBmV 37.8dB 35 213 8 Locked QAM256 32 657000000 -12.1dBmV 37.8dB 39 199 Upstream Bonded Channels Ch Status Chl Type Ch ID Symbol Rate Freq Hz Power 1 Locked ATDMA 1 5120Ksym/sec 35800000 32.3dBmV 2 Locked ATDMA 2 5120Ksym/sec 29400000 32.8dBmV 3 Locked ATDMA 3 5120Ksym/sec 23000000 31.7dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0dBmV
Thank you vkdelta.
Is it an internet service issue then?
When I complained to the service provider about the interruptions, they said it must be the fault of my modem/router, because everything is fine on their end.
