jonbartbeck
Jan 05, 2020Aspirant
How to turn on bridge mode in C7100V
I just got an Eero system and it says I should but the Netgear unit in bridge mode. Looking for how to do that on my Netgear box says to go to advanced tab and advanced set up and change the NAT sett...
antinode
Jan 05, 2020Guru
> [...] Looking for how to do that on my Netgear box says to go to
> advanced tab and advanced set up and change the NAT setting [...]
At what, exactly, are you looking, and what, exactly, does it say?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Set Up the
Modem Router in Bridge Mode"?
- jonbartbeckJan 13, 2020Aspirant
Helpful, thanks. I had tried it but (I guess) forgot to connect my computer cable to the new router (Eero). I had also been misled by this post: https://kb.netgear.com/000038798/How-do-I-set-C7100V-into-Passthrough-Bridge-Mode
- FURRYe38Jan 14, 2020Guru - Experienced User
You would connect the PC to the C7100 first when it's in router mode then make the change there first. There should be a NAT mode that you disable on the modem. This changes the C7100 to modem mode only. Then connect your external main host router to the modem. You should power OFF the modem and router for 30 seconds then back on.
- jonbartbeckJan 14, 2020Aspirant
Thank you but ... for the life of me I couldn't find the "NAT" mode. It's definitely NOT where that page says to look, and I looked just about everywhere else, too. What's in the user manual (switch off router mode) did work. Of course, now I can't access the Netgear through routerlogin.net or 192.168.0.1 but that's no issue.
