jonbartbeck
Jan 05, 2020Aspirant
How to turn on bridge mode in C7100V
I just got an Eero system and it says I should but the Netgear unit in bridge mode. Looking for how to do that on my Netgear box says to go to advanced tab and advanced set up and change the NAT sett...
DarrenM
Jan 08, 2020Sr. NETGEAR Moderator
To set up the modem router in bridge mode:
1. Launch a web browser from a computer or mobile device that is connected to the
modem router network.
2. Type http://routerlogin.net or http://192.168.0.1.
A login window opens.
3. Enter the modem router user name and password.
The user name is admin. The default password is password. The user name and
password are case-sensitive.
The BASIC Home page displays.
4. Select ADVANCED > Administration > Router Mode.
The Router Mode page displays.
5. Select the No radio button.
With this setting, the modem router works as a bridge and the router behind it obtains a
WAN IP address from the Internet service provider.
6. Click the Apply button.
Your settings are saved
jonbartbeck
Jan 13, 2020Aspirant
Thank you ... this worked (although I had previously found it in the user's manual per the prior post). I think my mistake was not giving it long enough to work. I had been misled by this article:
https://kb.netgear.com/000038798/How-do-I-set-C7100V-into-Passthrough-Bridge-Mode
