Jaybro
Apr 03, 2019Aspirant
How to turn your wifi off for others in your household without changing the password.
Hello, I am new to the forums and have been facing a dilemma of sorts which I hope I can find a solution for. Currently, I am using Time Warner Cable as my internet provider I have a Netgear C3000 ...
Apr 03, 2019Guru - Experienced User
You could always setup parental controls on the router. It allows you to block sites, set schedules, etc.
Or you could setup the guest network for them to use and the main network for you. whenever it gets to congested, shut off the guest network.
Here's the manual that shows parental control options or guest network options.
http://www.downloads.netgear.com/files/GDC/C3000/C3000_All_MSOs_UM_EN.pdf
