carehs
Sep 27, 2016Aspirant
How to use Bypass on Desktop
I set up a bypass account in the Genie and can bypass the blocks while using the Genie app on my Iphone, however, how can I use the Bypass while browsing on my Desktop so I can avoid the blocking? I have a small office and don't want people shopping on my time, however I need to shop for supplies from my desktop. Does the genie work on the desktop?
Thanks
- DarrenMSr. NETGEAR Moderator
Hello carehs
Yes you will use genie on the desktop there you can enter your bypass.
https://www.netgear.com/home/discover/apps/genie.aspx?cid=wmt_netgear_organic
DarrenM
- carehsAspirantThank you. It helps that I read the directions. I download the program on the Desktop, then just click on that when I want to surf unrestricted.. Thanks for your help
