rahul8886
Sep 25, 2018Aspirant
How to use NETGEAR AC1750 with ethernet input
Hello Community,
I have NETGEAR AC1750 which takes coax input. I it possible to use this modem with ethernet input of internet? I am trying to save the cost of buying a new modem to be able to use ...
antinode
Sep 25, 2018Guru
> I have NETGEAR AC1750 [..]
"AC1750" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label.
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Is that accurate?
> [...] I it possible to use this modem with ethernet input of internet?
A C6300 is a modem+router, not only a modem. It doesn't have an
Ethernet WAN/Internet port, so you can't use it as a router-only.
> [...] I am trying to save the cost of buying a new modem [...]
"a new modem" or "a new router"?
> [...] to be able to use ethernet input becuase I love this one and
> have been using it with coax input for a while now.
But it doesn't have an "ethernet input". To what would you connect
its Ethernet WAN/Internet port if it had one?
You might want to look at other Netgear routers whose model numbers
begin with "R".
It may be possible to use a C6300 as a wireless access point, not as
a full-function router:
https://community.netgear.com/t5/x/x/m-p/1463500
- rahul8886Sep 26, 2018Aspirant
C6300|AC1750 Cable Modem Router Docsis 3.0 - Yes this is accurate.
My ISP provides ethernet as input so my simple question is, can I somehow use C6300|AC1750 Cable Modem Router Docsis 3.0 with ethernet inout instead of a coax input. May be a converter?
- antinodeSep 26, 2018Guru
> [...] can I somehow use C6300|AC1750 Cable Modem Router Docsis 3.0
> with ethernet inout instead of a coax input. [...]
Still true.
> [...] May be a converter?
I don't know of one.
