libra22's avatar
libra22
Guide
Jan 04, 2023
How update DHCP in C6300
Hi Community,
I have netgear c6300, I'm unable to find dhcp address. I can see dhcp for ipv6 in advanced setup but can't find one for ipv4. I would like to update my dhcp address. If someone can help me to update dhcp server address. Thank you for your help.
    • libra22's avatar
      libra22
      Guide
      I'm trying to replace dhcp or dns with adguard home's address. I have setup adguard home in a device and it's askig to replace router's dhcp address with adguard home address. Adguard home address is 192.168.0.50. My router's dns is something like 208-67-xx-xx. Adguard will help to block ads. I tried to replace dns with adguard's address and clicked apply, the page display unable to connect error. Any idea how can I replace it?
      • plemans's avatar
        I've done something similar to that but with a pi-hole.
        A couple things.
        1. make sure before you change the dns to setup the adguard computer with a static or reserved ip address
        2. a backup computer is good as if the primary goes offline, then you have the 2nd one to function as dns
        3. You change it under the dns. go in and click on "use these dns servers" and enter in the adguard's ip address. and then hit apply. If it doesn't work, you might want to check with adguard or ensure its running properly as if it doesn't return a response, it won't set up the dns server link.
