rkruz
Feb 18, 2022Apprentice
How View log of Cable Modem(192.168.110.1) from my (LAN 192.168.0.1)?
My internet keeps dropping out. Id like to view the log of the cable modem a Netgear CM500 from my laptop on my LAN 192.168.0.1. How do I access the cable modem whos address is 192.168.100.1? The...
Feb 18, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
The cable modem is out of the LANs routers assigned address range and I cannot set the router to go out of 192.168.0.1.
Can you help?
