Tnguyen93
Feb 22, 2023Aspirant
I’m experiencing the same thing with my CAX30
I’m experiencing the same thing with my CA30 bought a year ago. It won’t even boardcast wifi can’t see wifi in any device, tried ethernet cable from modem to pc but it won’t work. Tested with old mod...
Tnguyen93
Feb 23, 2023Aspirant
Ethernet port is dead, can’t login to modem how can I downgrade the firmware
Feb 23, 2023Guru - Experienced User
All ports dead? Try other ports and swap LAN cables.
Try a factory reset and setup from scratch.
Do you have wifi connection with the modem? You can send the FW update over wifi if you can connect that way.
- Tnguyen93Feb 23, 2023AspirantNo wifi all port dead, no way to get access to the modem
