Michael6745
May 10, 2021Follower
I am looking for some home wifi education
I feel like a noob, but I am not. I just haven't researched the new technology in a long time. I am looking for some suggestions on how to set up my home wifi. I'm not sure where I should post thi...
May 10, 2021Guru - Experienced User
You can connect another Nighthawk or Orbi system to your modem:
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NightHawk or Orbi router gets from the modem. Then you can use the Nighthawk or Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Nighthawk or Orbi router to the modem, configure AP mode on the Night hawk or Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
I would try option#2 or 3 first with nighthawk or wifi mesh system.
Any Wifi Neighbors near by? If so, how many? Can use a wifi scanner to see whos around you:
https://itunes.apple.com/us/app/network-analyzer-lite-wifi/id562315041?mt=8
http://www.nirsoft.net/utils/wifi_information_view.html
https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/
https://lizardsystems.com/wi-fi-scanner/screenshots.php
http://nutsaboutnets.com
http://www.metageek.com/products/inssider/
https://www.sandman.com/knowledgebase/cordless-wifi-rfid-troubleshooting
Interferences from other wifi sources can cause problems.
