Timb811's avatar
Timb811
I cannot unblock a device on my C6300
I have checked the box for the BLocked device and clicked the allow button.  The processing bar comes up and nothing changes.  I click the apply button and nothing happens.  I was able to block the device easly , but unblocking is not working.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Timb811
    Have you tried another web browser or make sure a pop up blocker is not causing issues?
    DarrenM
    • Timb811's avatar
      Timb811
      I tried both using another web browers and tuning off the pop up blocker.  Still getting the same results.
      • DarrenM's avatar
        DarrenM
        Have you tried with another device? of so you may need to factory reset the modem which will remove this and set up the modem again.
        DarrenM
