happyq247's avatar
happyq247
Follower
Dec 20, 2015
I can't find other devices on my network.
my moden router is (CG3000DV268) old model. I can't not find my wifi network ( internet is working, i doubt is moden problem i bought new one too, the same problem happened) so i tried to call my cable company looking for help (roboooot. restarrrrt many time. They asked me to type 192.168.0.1 to do the WIFI setup. I followed the manuel to type username : admin (Admin) but its not work....Please I need the help form somebody.... Please..................i need the username  trying  to setup the wifi.....
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Happyq247
    The default username is Admin and the password is password if this is not working for you do a factory reset on the modem by holding down the reset button on the back for 10 seconds this will then default the modem back so that login should work.
    DarrenM
