James-TD
Sep 05, 2022Initiate
I do hate to advise of the same misadventure with the CM2000 Cable modem
I do hate to advise of the same misadventure with the CM2000 Cable modem. I've analyzed and confirmed safe operation of the surge strip I have connected to only the modem using a multi-meter and then...
Sep 06, 2022Guru - Experienced User
You'll need to contact NG support and open a support ticket if your modem is not responding to a factory reset or trouble shooting steps:
https://my.netgear.com/support/contact.aspx
Good Luck
