iRyan
Jul 17, 2022Star
I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem
I've been having the same issue since I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem. The only recommendation I can give is to manually set a prefe...
Jul 17, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Have you tried seeing the default IP address pool to 192.168.1.100 to .200?
Static IP addresses should be set outside a default IP address pool, not inside it per standard networking methods.
- iRyanJul 17, 2022Star
I have attached multiple screenshots to provide references to the information you requested from me, with the exception of the CAX30 wireless settings information page. Modem connection status all appears normal. I already have the router DHCP address pool set at 192.168.1.100 - 192.168.1.150 (I reduced the IP address pool to end at .150 instead of .200 because I found 100 IP addresses an unnecessarily large amount for our needs). Regarding the wireless settings, the 2.4G channel is set to Auto, although I actually have the 2.4 wireless radio disabled due to interference and signal drops it was causing with my Xbox headset's USB wireless transmitter that also operates on the 2.4Ghz band. My 5Ghz channel is set to 161, at the recommendation of a Netgear support agent I had spoken to a few months ago when I first experienced these wireless connectivity issues. To answer your question about WiFi neighbors.. I live in an apartment complex with many neighboring WiFi signals in my building, as you can clearly see in the very last screenshot taken from the Nighthawk mobile app on my phone. Hopefully all this info helps and feel free to let me know if there's anything else I can provide that could help with this troubleshooting. Thanks for your help!
Modem Page 1
Modem Page 2
CAX30 Device Information
LAN Page / Router DHCP
Neighboring WiFi Channel Statistics
