iRyan
Jul 17, 2022Star
I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem
I've been having the same issue since I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem. The only recommendation I can give is to manually set a prefe...
iRyan
Jul 18, 2022Star
I'll try lowering the transmit power on my 5Ghz network, but I'll just keep the 2.4Ghz radio completely off since we never used that band to begin with. Do you think changing channel 161 on my 5Ghz band to a lower number would improve the disconnection issues at all? I used to have it set to 48 before Netgear suggested 161, but the issue still persists and I'm hesitant to try going back due to channel interference in my apartment building.
Jul 18, 2022Guru - Experienced User
Once the power is lowered on the 5Ghz radio you can use any channel on 5Ghz.
- iRyanJul 18, 2022Star
Thanks for all the assistance. I'm tech savvy and consider my knowledge of networking to be above average, but the issues with the CAX30 have me pretty stumped. I've had 2 of them and both have been plagued with issues in one form or another. A point has to come when Netgear admits the device has either firmware or hardware issues. It's been a frustrating experience to say the least.
Anyway.. take care and again, I appreciate your help!
