iRyan
Jul 17, 2022Star
I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem
I've been having the same issue since I first purchased the CAX30 over a year ago and still have yet to find a solid fix for the problem. The only recommendation I can give is to manually set a prefe...
Jul 18, 2022Guru - Experienced User
Let us know how it goes.
iRyan
Jul 19, 2022Star
Will do. WiFi is a-ok at the moment, but if the connection issue pops back up I'll definitely be back with to give you the news lol. 😄👍
- FURRYe38Jul 19, 2022Guru - Experienced User
Enjoy. 📡 - iRyanJul 19, 2022Star
No problem at all. To make this as easy as possible for you, I recommend going through these steps from a desktop or laptop PC you're certain is already able to connect to your home WiFi network.
- Make sure your computer is connected to your WiFi network.
- From your web browser, visit the router configuration site by typing: "192.168.1.1" in the address bar and press enter.
- To log in, use the following credentials... Username: "admin" - Password: "password" and click Login.
- On the left side of the page, click the tab labeled "Advanced" located directly next to the "Basic" tab.
- Click the "Security" column to expand it, then click on "Access Control".
- Scroll down the page until you see a section that says "View list of blocked devices not currently connected to the network" and click it.
Based on what you showed me earlier in your post, you'll likely see a couple of things in the list of blocked devices. You can fix the problem two different ways. You can either delete each device from the blocked list, or you can completely disable the Access Control feature which is what I recommend you do if you're not concerned with monitoring certain devices owned by family members.
Regardless of which method you choose, you'll want to make sure you click the "Apply" button on the bottom right part of the page to save the changes you made to the settings. If you can find the time to do it, I suggest taking the time to learn all the different settings you can customize in the router configuration site. They will give you better control over the CAX30 and its features.
Good luck!!
