ugweewusFollowerFeb 08, 2018I got a new netgear cable router/modem now I can't get my nest thermostat to connect
1 ReplyReplies sorted by Oldestroger1955ApprenticeFeb 08, 2018Does the Nest see the SSID? Is your wireless setup dual band, are you using smart connect feature? I have 2 Nest that connect to the 2.4GHz or 5GHz band.
