Rolson59
Sep 06, 2016Follower
I have a c6300 WIFI Cable Modem Router and it dropps wifi daily
II have a c6300 WIFI Cable Modem Router and it dropps wifi daily.
DarrenM
Sep 08, 2016Sr. NETGEAR Moderator
Hello Rolson59
Have you tried to change the wireless channels on the modem to see if the wifi does not drop?
DarrenM
kms6005
Oct 07, 2016Aspirant
i got same problem.. i did change channel... factory reset... i tried all the way i knew.. still same it just gone about 1-2 mins.. help me plz
- DarrenMOct 10, 2016Sr. NETGEAR Moderator
Hello Kms6005
If you have tried all of that I would suggest contacting Netgear support if your modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
