Rolson59
Sep 06, 2016Follower
I have a c6300 WIFI Cable Modem Router and it dropps wifi daily
II have a c6300 WIFI Cable Modem Router and it dropps wifi daily.
kms6005
Oct 07, 2016Aspirant
i got same problem.. i did change channel... factory reset... i tried all the way i knew.. still same it just gone about 1-2 mins.. help me plz
DarrenM
Oct 10, 2016Sr. NETGEAR Moderator
Hello Kms6005
If you have tried all of that I would suggest contacting Netgear support if your modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
