BrettJohn
Jan 22, 2021Aspirant
I have a C7000v2 modem and the internet light recently started blinking amber/green
Recently the internet light on my modem has started continuously blinking alternately between amber and green. This is not mentioned in the manual. The internet connection is working fine and the s...
Jan 22, 2021Guru - Experienced User
do you have a screen snip of the cable connections page and the event logs?
I'd also check your coax lines for damage, kinks, bad/old/cheap connections, extended runs.
If you have any splitters, amplifiers, or attenuators in line, i'd remove them.
