Johnnybarr
Nov 28, 2023Follower
I have a CAX30 Cable Modem Router but I can NOT access the dashboard on my PC
My PC is hardwired to the router. HOWEVER, I can not access the dashboard when I log it from my PC - it just shows me as "logged in" but it's a white page with no radio dials to control or view anyt...
Nov 28, 2023Guru - Experienced User
What browser are you using? Try MS Edge or Firefox. Clear out all browser caches before entering the modems web page.
If you can get in, I'd update FW:
A factory reset and setup from scratch maybe needed as well:
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
