toraritte
Jul 29, 2023Aspirant
I have a CAX30 so how do I determine which USB storage drives are compatible with ReadyShare?
I found the official article listing all the Netgear products and the drives they support, but there is no CAX30. I guess it must have a sub-designation that I haven't found yet, so any help to find ...
toraritte
Thank you for the replies! I initially posted this because no drives seemed to work after I plugged them in (NTFS, Ext4, etc.), but, as it turns out, I should have been more patient... The drives were between 2TB and 4TB, and none of the resources mentioned that they will be scanned first, so it just took a while. After giving the CAX30 some time, all of them worked out.
Thanks again and have a great day!
- michaelkenwardJul 29, 2023Guru - Experienced User
I haven't come across that. Perhaps you are referring to the media server.
Data stuff lands immediately. As long as you have told Windows to do SMB1.
