virgilsandberg's avatar
Aug 31, 2021
I have a cm500
I am trying to hook another cable modum to my router but dont know how
  • plemans's avatar
    Trying to hook "another" modem? As in you're wanting to connect 2 modems?
    What router do you have?
    What are you actually trying to do in details?
    And what problem/error you're getting.
    We aren't there to see whats going on, what your setup is, or what actual problem is happening so details are key to us helping you.
  • StephenB's avatar
    This is in the wrong forum area (ReadyNAS has nothing to do with cable modems).  Hopefully one of the mods ( JeraldM ?) will move it for you.
    As far as the main problem goes, as plemans says, we need more details on what you are trying to accomplish and more details on what you have.  Most home routers don't allow you to connect more than one cable modem.
    • JeraldM's avatar
      JeraldM
      NETGEAR Employee Retired
      Thanks for the notification StephenB!
      I moved this forum post to the correct forum area.
      JeraldM
      NETGEAR Community Team
