AudioDave
Dec 21, 2023Aspirant
I have confirmed that this firmware downgrade occurred with my modem
I have confirmed that this firmware downgrade occurred with my modem, and that I have received the same notice from Comcast.
Further, I updated to the CM2050V AFTER being notified by Comcast th...
- Dec 26, 2023
Thanks for the input!
I have confirmed that the bulk of my problem is the Zyxel USG60 router. I put the drop amp back into the circuit as I would normally have it but plugged a PC directly into the modem for testing. While I am still seeing the previous events, with the USG60 out of the path, I am now seeing 940/25.
Apparently, the issues were the USG60 router all along.
As for WIFI, I already have a mesh system with 3 nodes (overkill but works).
I will be exploring firewall/router devices for something that has better throughput based on my service tier. The speed issues are NOT caused by the drop amp!
Thanks for the patience! Any recommendations for firewall/router in this speed tier would be appreciated. I'm considering the NetGate 4100 for a bit of future-proofing that meets by speed tier.
The USG60 is considered obsolete and no longer getting updates. Guess I have a better understanding WHY it is obsolete!
AudioDave
My WIFI is on my LAN, not part of the incoming router.
The router is a Zyxel USG60, firmware 4.73 (AAKY.2).
I am aware that the speed issue could potentially be a limitation of my internal network. However, I have connected a computer directly to the modem and seen similar results. I do not have the data from that test.
My bigger concern is the failure of the original CM2050V, and whether another firmware update could cause another failure. I'm also concerned about being forced to once again change modems or having to rent the Comcast modem.
Note that I do have a distribution amp on the cable side: Electroline EDA-FT08100 Drop Amp. All RF cables are RG-6. This is to eliminate passive splitters.
AudioDave
Additional note:
- AudioDaveDec 21, 2023Aspirant
Also, how do I verify that the ISP provisions the modem correctly? Is this something I have access to verify? Is this something the ISP should be monitoring and/or correcting without my intervention?
- FURRYe38Dec 21, 2023Guru - Experienced User
Something the ISP will need to check provisioning and signal levels up to the modem. You may need a onsite tech visit from the ISP and have them review the information given and the situation there.
