AUCEO
Aug 30, 2023Follower
I have Ethernet access but NO WIFI
I am having the same issues. I changed DNS Server Settings on one of my PCs to CLOUDFARE DNS SERVERS for both IPv4 and IPv6. I also disabled the UPnP option due to having to enter PortForwarding specifics into CAX80 settings.
I hope the issue is resolved/answered in this thread...I will update this generic post shortly.
For clarity: My issue is at least 3 times a day (sometimes as many as 8 times/24hours) it seems I have Ethernet access but NO WIFI. When I enter the CAX80 settings directly > ADVANCED > ADVANCED HOME > INTERNET PORT Window colored radial preceding the description will show Green if working/functional or "yellow" if not....Too often is NOT GREEN...forcing me to use the first window option of REBOOTING...this is a major issue for me due to being a Medical Doctor that allocates a lot of time with patients on line
1 Reply
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerIs Smart Connect enabled?
Is AX mode enabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
