isaacr77
Aug 28, 2019Tutor
I have problems with my c700v2 and Ex7000 extender
Hello, I have never written in a forum before but I am desperat, I have comcast and we have up to 250mgbs plan. We have around 14 devices and 2 of these are connected to ethernet. alot of the time my...
isaacr77
Aug 28, 2019Tutor
First of all, thank you for helping. I ran a speetest using ookla and got 76mbps down and 11 mbps upload. When you say modem connections I think on my router its cable connections so i took a screen shot of that. If you need more screenshots I will provide. Do I call or chat support xfinity for a reprovision?
Aug 28, 2019Guru - Experienced User
that was the screen but take a couple to get both download and upload. Your power levels for download are technically within spec but you have a bunch of errors. Plus from your speedtesting (provided you did it over a hardwired connection) you aren't getting the full speeds you're paying for. Here's where I'd start:
1. remove any splitters, amplifiers, bad connectors from the coas line entering your house. If possible directly connect the C7000v2 at that location. it reduces the chances of a bad cable/cord/splitter causing the issues.
2. Once thats done, retest your speeds. Again, make sure to do it over a hardwired connection. Directly connect to the C7000 for the testing.
Reason for all this is to first get full speed to your modem/router combo device. If we can't, then your ISP needs to check your line to determine why not. Many charge a service fee if the problem is within your house which is why I recommend just connecting the modem right where it comes in. It rules out other cables, splitters etc causing the problems and leaves it in your ISP's hands.
- isaacr77Aug 28, 2019Tutor
The cable is 2ft under the router connected without any cable splitters or none of that Do you want me to check outsidefor those? Also If this information is important about 2-3 yrs when we first got xfinity they had to wire everything new so they cut under the front yard and through our driveway to the backyard where the cables are.
- FURRYe38Aug 28, 2019Guru - Experienced User
Any splitters that maybe at a junction box outside on the house if there is a box, or someplace inside if you see anything. Other then that you be ok in that regard.
I would contact the ISP and have them check the signal and line quality up to the modem.
the cable is just one direct cable all the way to the box which is connected to another cable that goes to the ground. I am on auto for 2.4ghz so im changing it to 6,for 5ghz im at channel 153
