isaacr77
Aug 28, 2019Tutor
I have problems with my c700v2 and Ex7000 extender
Hello, I have never written in a forum before but I am desperat, I have comcast and we have up to 250mgbs plan. We have around 14 devices and 2 of these are connected to ethernet. alot of the time my...
isaacr77
Aug 28, 2019Tutor
Thank you also for replying, My EX7000 is 25ft away i measured it and when you say change the channels im not sure how to do that. Also i was looking through the advanced settings and there is a WMM for 2.4ghz and 5ghz both are on. Also I will look for beamforming to check that our
Aug 28, 2019Guru - Experienced User
25 feet maybe a bit too close, try setting the EX out at 30 feet if you can. Having too much wifi over lap between the modems wifi and the EX wifi can cause some problems.
isaacr77 wrote:Thank you also for replying, My EX7000 is 25ft away i measured it and when you say change the channels im not sure how to do that. Also i was looking through the advanced settings and there is a WMM for 2.4ghz and 5ghz both are on. Also I will look for beamforming to check that our
- isaacr77Aug 28, 2019Tutor
Ok is it ok if i set at 33ft? i measured again and its the next closest place i can put it on furniture
