enotsenol
Jul 19, 2022Follower
I have the c7000v2 and we have been having problems with losing connection
I have the c7000v2 and we have been having problems with losing connection, slow download and extremely slow (low kilobytes at times) uploads. Cox is our ISP and according to the knowledge base the a...
Jul 19, 2022Guru - Experienced User
Are the devices connected via wireless or ethernet? Ethernet would be best.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Fw is ok to have later than what is posted. KB may not have been recently updated.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
